- Mar 15, 2019
- 713
My SB 10 has a 1" dial on the compound and 1-1/4" on the cross slide and I've always wanted larger dials. So I made new dials using the dividing head to do the graduations. Worked out ok, new dials are 2.25" and 2.5" which are clownishly large but easy to read as there is plenty of room between hashmarks.
I will likely turn down the compound dial and redo the graduations. The engraving tool on that one was not rigid enough and wandered a bit.
