I just completed a Clough42 ELS install on my G0709. Thought I'd quickly share lessons learned:
Hope that's useful to someone someday.
- The gearbox is stiff. I couldn't drive it 1:1 with a 180W servo. I'm driving it 6:1 with a 3d-printed 11-tooth 1.5 module gear on the servo (seems to damp vibrations better than metal, so planning on it being a wear part I replace occasionally rather than cutting a permanent one in metal). I think if I were starting from scratch with what I know now, I would splurge and get the substantially more powerful 750W iSV2-80TR-48V750A to drive the gearbox. Or if I wanted a bigger project, just replace the whole gearbox.
- James's firmware doesn't support all the threads that the gearbox provides, even ignoring mod/diametral pitches. I wrote a PR for James which adds a digit of precision and optionally adds more threads (all the ones on the G0709 except for mod/diametral) which makes it a straight superset of what's supported on the G0709 for threads, anyway.
- I also merged that PR with Steve Ward's thread-to-shoulder, angular position reporting, and arbitrary metric thread spec PR.
- Here's the firmware I'm running — it is set up for 6:1 driving ASW1 with a servo set for 168 steps/rev, but you can use my Characterizing the G0709 quick change gearbox post to choose a different ratio.
- You can't use a stepper and get precise threads through the gearbox, as far as I can tell. Need to use a servo and choose a number of steps per motor revolution that gives you an integer steps per lead screw result. My PR has a Python one-liner to help find those.
- The firmware doesn't know that Z and X feed rates are different. Mine is set up for Z, and just know that X is about ¼ of Z.
