We are building a project for the irrigation system that will have its own thread but we thought we would share an idea for our magnetic cover latch.
Our cover uses a set of parallel arms to swing down and away.
It was an afterthought so we did not have room for offset arms so we needed to come up with a way to keep the cover closed.
A local well stocked hardware store had nothing suitable.
Our space was about 5/8 inch and when closed is 2 parallel surfaces.
Went to the notions department for magnets as we were told they had some with screw holes.
Nothing suitable but we noticed some magnetic cup hooks.
Ordered 15 for 7 bucks.
Had a metal knob, not matching threads in both but close to 8-32 so we tapped both and cut a long screw as all thread.
Made a steel round for the magnet to grab as the project is aluminum.
One was existing hole, other side was close to our lettering, if only we made it a bit higher, we removed a bit from the back to clear the letters.
Made a tool from angle aluminum to hold the transfer punch perfect to have hole in cover align.
Photos of the parts and the catch.
Easy to make and can be in many places.
We have glued into wood the screwdriver magnets and a woodscrew in mating part, this worked much better for our applicatiin.
Sent from my SM-G781V using Tapatalk
