Hi. There is something I don't quite understand about these instructions for making a simple boring head:
It seems that the holes for the split cotter retaining clamps for the boring tool shanks are too close to the center line of the holes for the shanks. If my calculations are correct, there is only 1/16" for the screws holding the clamps to clear. Of course, I didn't figure this out until right before this step. It seems that the split cotter screw size was not specified. It certainly is not #10. Maybe #8, but that still would not clear. It seems that one would need to go down to #5, but that would still be tight. Clever grinding on the central threads of the screws; would that do the trick? A good use for a Dremel type tool?
Lathe Boring Head - HomemadeTools.net
A small boring for the lathe made many years ago and has performed very well. It can be easily made on the lathe from M/S as was this one, and as I
www.homemadetools.net
