Hello.
I'm just getting started in the world of machining. I have a bunch of old tools and tooling from the 70s and 80s from an old machinist (my father). One thing that I am running into is how to clean up flat tools with out modifying their flatness or parallelism. I'm dealing with 123 blocks, parallels, combination squares and other various measurement/setup tools that have minor surface rust and pitting on. My question is when it comes to the things that need to be flat and or parallel, what is the best way to go about cleaning those up with out modifying them? I just got finished cleaning a Starrett 4 inch combination square. My method was to take any flat spot and sand the face on a flat granite surface using lapping paper. This did a great job for the blade and seems to have done a good job with the 90 degree side with out modifying it too much. It also revealed that the trailing edge of it is worn out and not all that flat anymore (there was no rust, just dirt and black oxide). Is this a good method? With out using things like a surface grinder or a mill, how would you go about cleaning these tools to keep them flat and even?
