Hi folks,
Almost daily I use some very fine Grobet Pillar files in smooth cuts, #4, #6, and #8. I think the #8 file has around 250 teeth per inch. In use small bits of swarf build up quickly in the teeth and have to be physically pushed out. Chalking the teeth doesn't help much, if at all.
My current maintenance program involves using a small (1/4"x1/4") piece of hard bamboo, or a flat piece of cartridge brass to push the swarf out of the teeth. When the file is relatively clean it is stored in an upright jar of Hoppe's #9 Gun Cleaning solvent.
It works, but there simply has to be a better way. Someone suggested blasting with glass beads, but there's no room in my 16x20 shop for another big piece of equipment.
Any suggestions? Thanks in advance,
Harry
Harry
