In my continuing effort to rebuild my model 1875 Logan I kept finding that the front headstock bearing after sitting for a couple days would be locked tight. If I stuck it in the solvent tank it would loosen up and feel "ok", but not great. If I blew the ball area of the bearing out with air, it would feel sticky or gummy. I went back and forth several times and then would let it sit for a day or two, and same thing. Bearing locked for rotation by hand. I was beginning to think I would just have to replace the bearing as I couldn't get it cleaned out. As a last ditch effort(why not if I'm just going to throw it away anyhow) I squirted a very powerful concentration of ZEP purple into the bearing. I knew immediately that it was doing something as the bearing went from sticky to loose and brown fluid began coming from it. I let this sit in the bearing for at most two minutes and then flushed the bearing with HOT water at a good pressure. I then immediately sprayed it full of WD-40 to get rid of the water. This process made it feel like a brand new high quality bearing. I let it sit one day and it is still loose and smooth. Just like new. I think that the old grease had just hardened inside the bearing and would lodge in the balls after it sat awhile. I will let it sit for a couple days now and see what happens. I know from cleaning up other machined surfaces that you don't want to leave the ZEP in there too long and especially don't want to let it dry. It seems to have worked for me. At least so far. This may be old news to you guys, but in doing a search for bearing cleaning I didn't find anything like this, so I thought I'd post it here
