clausing 8520
Dbike199
Apr 22, 2014
14
A friend of mine told me about a Clausing 8520 within a reasonabledrive. I have only seen pictures of it and it appears to be in pretty goodcondition. However I did notice it is missing the handle for the fine feed on thehead. Based on what I have read the fine feed gears are easily stripped out. I’mthinking they are stripped and someone in the mills life took the handle offnot to do anymore damage or just lost it.
My questions are: How difficult is it to replace the handle? And can you buy replacement gears? If yes,can you direct me from whom?
Thanks for your wisdom,
Mark
There are two handles there. One is for rapid down feed and a wheel for fine down feed. The first pic shows where the go. Second pic ie the wheel for fine feed. Both push on and are located with a pin. Tho use the fine feed you pull the back mount (Handle end) to engage it. Push it back in to disengage. They are easily mounted and removed.
"Billy G"
Correct, the round fine feed is the one missing. Do you think it will be difficult to find a replacement?
If you don't need to have the exact factory hand wheel, you can get a hand wheel from McMaster-Carr that would be almost identical.
I got mine from Clausing last year. Any configuration of that style will work. The original is aluminum. Just put the pin in and go for it. You will love that machine.
"Billy G"
It appears the wheel issue is solved. What about the fine feed screws? Thanks!
Any resources for them if they need to be replaced?
Clausing still stocks and makes a lot of OE parts for the 8520's too. The gears are available, but they aint cheap either. You will love that machine, it is the perfect size for our shops and can do the work of much larger machines.
Bob
I never imagined they would have parts on a 1966 model. Thats good to know.
Thanks for the information.
Interesting that the gears are still available. They are stripped out in my 8520, only one gear is actually missing any teeth if I remember correctly. I was planning on making my own replacement gear, but I might just rethink that a little bit, depending on what they cost.
On the other hand, you might get lucky. In other words, maybe the handwheel got lost, but as a result your gears might still be in good shape. I guess it doesn't really matter, you will love the 8520 whether the fine feed works or not!
I know on my Johansson B12, which is the older brother to the 8520, the handles can easily be removed. Maybe the just got tired of them falling off. Good luck on the machine. You'll love it. Easily one of the best home mills you can get, short of maybe a full sized B'port.
