- Aug 13, 2020
- 1,340
I got busy over the past week. I copied these table clamps from Mike's workshop. The only difference is I drilled the hinge hole and cut the slit at a slight angle, so that they press down when used.
In order to cut the slit, I need a slitting saw. Bought a metal cutting saw blade for $20 off Amazon. Turned the threads off a large he'd head bolt, turned the head down to a tight fit for the blade, and then tapped the head side for a screw. Turned a socket down for them cap. Works perfectly when chucked in an ER32 collet.
