CL57T stepper motor driver, how do you hook up the alarm?
WobblyHand
H-M Lifetime Diamond Member
Dec 18, 2019
7,339
The manual isn't clear, at least to me. The typical connection looks incorrect in Figure 4. They have the collector of the NPN photo-transistor connected to the negative of a battery and have labeled it as COM-. The emitter seems to be the alarm signal. That would mean the collector is connected to positive and ALM would go to a load and then to ground. So I'd guess that the label should be COM+?
Anyone used this signal before and figured it out? I'm trying to work through a cable diagram for my ELS and wanted to add in this signal into the cables I make. I am not using the alarm at the moment, but when I button things up in a box, I would like the controller to be able to read this signal, since the little light will no longer be visible.
Figures 7 & 8 don't make much sense either, they don't seem to make sense with reference to Figure 4.
Can someone point me in the right direction?
I agree it looks like the polarity is wrong on the opto isolator in figure 4. How about just checking it with an ohmmeter or an LED and 1.5V battery? I don't see any real reason you need a full 5v for testing, although likely they have some internal current limiting resistor not shown.
It's completely wrong. Someone didn't have a clue
An NPN opto conventional current flow is from collector to emitter
Two possibilities:
1) the Com- is actually the two emitters and the two collectors are the outputs OR
2) the Com- is actually supposed to be the B+ supply
Your mission Jim, is to determine which it is
It is a simplified circuit, and there has to be a lot more there, because they claim the transistor can source or sink 100mA. Figures 7 & 8 would indicate a standard NPN transistor output. I think Figure 4 is utterly wrong. It would make a lot more sense, and would match up with the latter figures if COM- was attached to the emitters and ALM and PEND were connected to the collectors.
It's completely wrong. Whoever drew it has no clue. I'm guessing the Com- is actually supposed to be the B+ supply
I agree about they had no clue. It makes no sense on several levels. They have the "battery" negative connected to COM-. Then the emitter would have to be connected to a more negative supply so the current would flow. Maybe they needed a flipped version of the opto isolators with emitter up, but forgot to do this before releasing the drawing. Clearly no electrical engineer reviewed the drawing before release. Not only is it wrong, but it is misleading.
Well bugger. I'll have to go measure it sometime. Have things all apart, trying to figure out how to wire it all in a box, with connectors and stuff, so it will have to wait for a bit.
You can test it non-destructively with a 9 volt battery and an led + 1k resistor
I figure I can test it when the cables are in place. I still need both wires, no matter what.
Hey, I have this exact drive was just getting things wired up to a mesa card. I was looking at the alarm wiring as well and came to the same conclusion, lol. Ended up here. Did you figure it out? Mind sharing? I have a variable power supply I could hook up, but since I'm not there yet, thought I'd see what you found.
Not yet. Haven't got to it. I do have to say that if the alarm is set, the motor has stopped and all kinds of bad stuff has already happened. Probably a lot of noise and breaking things! Nonetheless, someday I will figure it out.
