- Feb 19, 2013
- 220
Does anyone know how to prevent a JT-33 chuck and arbor from separating? Upon receiving my tooling, I placed the arbor in the freezer after cleaning and degreasing it in preparation for use. For about a year,I have not had any problems with them as they were a match - All of a sudden, one doesn't like the other and continues to file for separation and divorce.
After attempting to clean and degrease it again, determine if any burrs exist and use metal cloth to rough up the surface slightly on both arbor and chuck, giving one the "cold shoulder" and mate them back together, they continue to have bad feelings for each other.
I originally thought that I had a "bend" drill but after swapping this bit out for others, it starts to cut (2 threads), then separation. I predrilled the hole at 1/4 inch, increasing about 1/16 diameter to full depth. When I get up to around 3/8, it starts it's problems. I am feeding moderately, not forcing, using cutting oil, appropriate speed, retracting after about 20 thou.... placed dykem and no gaps or scrapes on the arbor or chuck are noticeable. The last time, I even attempted to back the jaws out from the chuck and using a hammer and wood, strike gently on the arbor to attempt to "set" it. Any thoughts? Solutions?:noidea:
