- Mar 10, 2012
- 125
Actually I finished this a while back but just found the pics. I bought a carbide aluminum cutting blade for my Delta 36-220 chop saw for cutting stock for projects. It worked great until I miscalculated the overlap required for the stock I was cutting (the saw came with rubberized plastic fences and a plastic table insert around the blade). The cut off end of the inch and a quarter square stock bound between the blade and the less than rigid fence, shot out the back, off the closed metal overhead door, the ceiling, and finally the carbon fiber intake cover on the one off hand hammered aluminum tank on my Ducati. After I had depleted my reservoir of colorful expletives and had time to be thankful it was the tank and not my head it last banked off of, I decided to replace the now broken fence and plastic table insert with aluminum (the insert had melted when I cut some heavy steel tubing with a fiber cut-off blade to roll my mill in place when the forklift wouldn't go under the door).
After cutting the fences out of quarter inch x three inch stock, drilling, countersinking and mounting them, I roughed out the 3/16th's aluminum table insert on my wood bandsaw, and sized it to fit the slot on the mill.
Next, I taped the original to the aluminum piece, and radius-ed it on the disc sander and slotted and drilled it in the milling vise. I faced the insert with a fly cutter to pretty it up.
Here it is all tightened down.
