I have been getting interested in using inserts for my lathe. HSS works fine, and I have plenty of it, but I got some large negative rake triangular inserts. Earlier, I posted about my surprise when I could find a narrow range where they would work with a cobbled together toolholder. Anyway, they're no use otherwise, and it is better to go out to the shop and give them a try than to endlessly surf web (which is no good for you in the long run).
After some initial success, instead of getting recommended tools from Aliexpress, Shars, or Ebay, I went to a neighbor who was liquidating and bought a grab box of cutting tools. Inside this box were two insert toolholders. One was a positve rake trangular insert holder, and the other held what looked like 3/8" IC TNMG inserts. It was a little confusing, though, since this toolholder had what appeared to be a right hand chipbreaker insert in a left hand toolholder. I tried searching on the web, but all I found was "use R chipbreaker inserts with right hand tools and use L chipbreaker inserts with left hand tools; the insert shown has an R chipbreaker." This tool seems to be switched. I couldn't find any simple illustrations. Is this on target?
