H
Hukshawn
Forum Guest
Register Today
I played with that this past weekend. I was tracking down some chatter, and I knew that a more aggressive cut can stop chatter in many situations. I had some play in the cross slide because the screw wasn't held tight enough to the handwheel and saddle. That resolved the worst of it, and allowed me to go for much deeper cuts than before. Still nothing more than about 0.040", but that's a vast improvement over what I had been doing. Anyway, I tried varying the depth of cut, spindle speed, and feed rate, and it was fascinating to watch the different chips produced from a broad radius bit (one that is so large it barely goes into the tool post with some mallet tapping, so it wasn't likely to blame for the chatter).Increase your feed rate. Quite often, taking too light a cut at too slow a speed will produce stringers. Aluminum does this anyway but feeding faster helps.
