- Apr 21, 2015
- 894
Warning: I tend to over-analyze and write a lot. Terribly oversimplified version: What is the cheapest way to hold an item for surface grinding when the opposite side is not flat?
I inherited a surface grinder, as detailed in a vintage machinery post a while back. I don't have a mill and have only distant access to a lathe, so it's kind of silly as the first real metal machine, but I wasn't going to pass it up. It came with a great selection of grinding wheels, a permanent magnetic chuck, some angle plates, and some magnetic 1-2-4 blocks. And I've tuned it up, with guidance from this forum.
I have only played with it so far, grinding scrap for practice. Now I am wanting to use it to restore some vintage woodworking bench planes. But while the soles of the planes are nearly flat, the opposite sides are far from flat. Obviously I need to hold them in a vise somehow. I don't want to spend a lot on tooling for this machine right now, because getting at least a small mill is a higher priority for me. Is there a cheap option for a surface grinding vise that would be serviceable?
Regardless of the type of vise I end up using, I am picturing clamping it pretty tight and then tapping it around while indicating it as I run the bed in all directions, to get it as close to flat as possible before grinding. Then using the now-flattened sole to register against the known-square vise to flatten the sides. (I plan to use the planes on shooting boards, for those who are familiar, and thus the need for the sides to be square.)
I keep looking at those roughly $20 drill press vises and wondering if that might not be good enough. First grind the vise perfectly square then just clamp it in tight. But I've never used one of those (I have a cheap cross-slide vise for my drill press) so I have no idea if that's realistic or if they are far too flimsy/flexible. But we're talking about grinding, not milling, where a magnetic chuck is sufficient to hold workpieces with a flat surface, so maybe??
I would love to hear from both your experience and imagination/brainstorming, but please state which is which.
