- Jul 15, 2020
- 422
While 8020 aluminum extrusions are a great substitute for steel in many fabrication projects, it can be quite expensive. You can greatly reduce the cost of a project by CNC plasma cutting your own brackets. Here is an example:
The eight brackets shown below cost under $10 to make, including 1/8" steel, paint, and a two dollar allowance for consumables wear and electricity. The cheapest price I could find for eight of the 10 series 8020 brackets, was $5.95 each, or a total of $47.60 plus shipping. While the 8020 version is 3/16" thick, the steel is just as strong or stronger. Use 1/4" flat washers to make up the thickness difference.
I didn't take the time to clean these up much, as it wasn't important for my project. A few seconds on each side at the belt grinder and they would look as good as the genuine article.
The larger and more complicated the bracket, the greater the savings.
