- Jul 20, 2014
- 1,386
I'm very new to machining but learning quite a bit quickly from all the great posts and info here.
I've been drilling holes in 1018 steel with a drill press using a hole starting bit or spot/center drill.
Sometimes I get chatter when I start the next size drill up after a shallow pilot hole.
I;m thinking that I may be using the wrong point angle, i.e. 135° drill after a 118° starter hole drill.
Do I need to follow the correct sequence of point angles or is the chatter from something else?
The holes are 1/2" in 3/8" thick 1018 steel. Could it be a speed problem? Not sure of the RPM's
on the last attempt. The drill press is very old with a lot of run out. (I saw this when I reamed a few holes
the other day and the long reamer showed how bad the run out is). The holes don't come out elliptical
but clearly not even close to round).
Thanks. I'll take all the help I can get.
