Well I learned how to chase some internal threads today....not nearly as hard as I thought it would be.
I was making a spindle thread protector for my SB9 and was about 3/4th's finished when my home made internal threading tool bent. My fault not watching what I was doing close enough. I made another tool out of some old sucker rod and a cheap import 1/4" bit. I drilled a 9/32nd hole in the sucker rod and used a small square file to make a square hole for the bit (really didn't take very long) and the drilled and tapped a set screw in the end to secure the bit. Worked really well.
Chasing the threads wasn't hard after I thought about it for while.
Engage back gear-engage half nuts on the right line-run the carriage under power into the hole-then use cross feed and compound to put the bit into the thread exactly--turn by hand to assure all was good-reset cross slide to zero-resume cutting threads (hardest part was trying to see the thread with the tool in the hole)
Turned out good!
Turned out good!
