- Dec 19, 2013
- 73
I have some 5/8 rod that I need to turn a 1/2 shaft at the end for a length of 5.75mm. Then I need to part off the rod at an overall length of 2" + 5.75mm, repeat, repeat. So I need to go from a turning tool to a parting tool which would have a new Z value.
1. I could touch off the parting tool at the end of the piece, reset Z to zero and continue on to part off.
2. I could determine the difference between the cutting edge of the turning tool and the parting tool (h0w?) and allow for this difference in the program.
3. Or ??????
What is the normal method of dealing with changes in the Z position when you change tools?
Machine is a converted Grizzly 0602 running Mach3
3. Or ??????
