- Mar 26, 2018
- 8,666
A dirty job to say the least.
I changed the coolant in my Jet horizontal saw. What a PITA!!
I try to keep my equipment in good shape. This is the first time I changed the fluid since I bought the saw in early 2019.
It was due.
The reservoir has no drain. It has an opening for the pump and the inlet/screen.
The pic has the fresh fluid.
I have two gallons of nasty chip infested old coolant. Fortunately I can take it to work and dump it in the mop water drum for recycling.
Your thoughts on the water soluble oil or the synthetic?
I use the same concentrate for all my machines. Surface grinder, mill, lathe......I just ran out of the water soluble stuff.
It was due.
