- Apr 28, 2018
- 82
Hi,
Thought I would put these pics up of an old grinder I had bought at a Flea Market, years ago and just getting to now.
It was in pretty bad shape, and sported a flat wheel pulley, that was pretty useless, with a small motor.
Had all the holes filled with dirt dauber nests, and was missing the Gits oil cups, I believe it had originally.
Has babbit bearings and would date it back to the 1930's at least.
Ordered some dies and taps I needed to chase all the threads and got on the lathe and made some bronze caps for the oil holes that were threaded.
Milled a key way and put on a keyed cast iron V Belt Pulley.
Chased the threads on the main shaft as they were all dinged up and would not take the nuts required.
Found an old 1/3 HP motor and cleaned it up and made a tensioned base for it.
All in all a little bit of work, but now runs great, and can't really bog it down, and is bigger anyway, from what I had.
Wondering if anyone else uses a belt driven grinder/wire wheel???
