Thanks to all the help from this forum, I have my 1228 set up, broken in, and running nicely.
I was told that after the break in period I should change the oil and I think that is where I am at.
This leads me to my question: what do you guys use as a funnel at a drain pan?
As for drain pans, I found this one from US Plastic Corp (which is even sorta color matched ). Once I found it, I realized I don't l know how much oil is in there so I am wondering if this will hold enough?
I'm still looking at getting the oil into the machine and I am sure this is problem that has been solved many times over, so please teach me.
Thanks,
Mark
Thanks,
Mark
