- Nov 8, 2011
- 1,678
I need to order 2 sprockets and don't know what chain size I have center to center of the links is .425
if you are a little off in your measurements you may have either #40 or #41 here's the specs:I need to order 2 sprockets and don't know what chain size I have center to center of the links is .425
ANSI B29.1 roller chain standard sizes | ||||
Size | Pitch | Roller diameter | Tensile strength | Working load |
25 | 0.250 in (6.35 mm) | 0.130 in (3.30 mm) | 781 lb (354 kg) | 140 lb (64 kg) |
35 | 0.375 in (9.53 mm) | 0.200 in (5.08 mm) | 1,758 lb (797 kg) | 480 lb (220 kg) |
41 | 0.500 in (12.70 mm) | 0.306 in (7.77 mm) | 1,500 lb (680 kg) | 500 lb (230 kg) |
40 | 0.500 in (12.70 mm) | 0.312 in (7.92 mm) | 3,125 lb (1,417 kg) | 810 lb (370 kg) |
Remeasured the chain it is .350 pitch & .200 barrels
