- Nov 7, 2019
- 481
Not so much machining related but I want some mechanical ventilation in my garage/workshop so I can quickly change out the air if it's dusty or smoky.
Looked at commercial alternatives and the price quickly gets out of hand ...
But I figured I already have a bunch of motors and materials, so why not just make my own.
Designed and printed a fan, 90% on intuition "what might work well" and 10% inspiration from various websites.
The 1-phase induction motor is rated for 320W and draws around 200W with this setup.
The airflow "feels" good but I want way more.
I printed a second wheel with more blades and another scoop angle, which increased the air speed a tiny bit BUT made me realize I need to be more scientific if I want to find out what works best.
So I designed this "modular" wheel. It can take 4, 6, 8, 12 or 24 blades and adjusting the angle on any one blade will force all others to follow along.
The blades are slightly convex which in hindsight would've been better if they were flat as this might skew the results.
Furthermore I added a long snout to the blower to force it to work against more back pressure and make it easier to get a reading on the airflow/airspeed.
I considered adding a tube so I could check static pressure but been too lazy so all I'm measuring is power draw and windspeed out of the nozzle/snout.
Testing all configurations on this, the power draw only differed by a few watts, going between 210 and 216W so it doesn't seem to be a major factor at this size.
Graphing things out, this is what I have so far.
"1" step is roughly 45* so the blades can move almost -90 to +90 degrees from neutral.
In hindsight I should've made this more sensitive to have more steps between -30 and +30 and skip the rest of the range.
Generally any blade quantity seems to perform well at neutral angle and 2 out of 3 seems to perform even better at roughly 45* forwards ie pointing in the direction of rotation/travel.
The lonely dot is a separate "fixed" wheel I printed out with 60 blades, because this wheel does not have the adjustment feature it's almost 10mm thinner and I could thus move it in and out on the motor shaft to test how the gap between inlet side and fan wheel side affects output.
Whilst not graphed it did seem to have a major effect, with ~8mm gap the airspeed in the output was 10.1m/s and with ~1mm gap the airspeed was up to 11m/s, improvement of ~9% just by closing the gap by 7mm.
And here's the test with the 60 blade fan.
I'm printing a 100 blade fan to see if that increases the airflow even further or if I'm starting to hit some kind of peak.
If I manage to find some kind of sweetspot when it comes to blade quantity, it'd be interesting to test different lengths of blades to see if I can up the pressure and flow further.
Another factor I'd like to try is RPM variation. It's difficult to test with this motor but I have a 24V 1700rpm DC motor that with a modified fan wheel could be modulated much easier. Whilst I'm guessing the flow is fairly linear to RPM, I won't know for sure until I try it.
It'd also be interesting to compare if there's specific RPM's where the flow is greater related to the sound levels being produced.
Whilst it doesnt need to be silent, it'd be nice if it's not louder than necessary.
