- Jan 5, 2018
- 28
I saw a video on youtube on how to center a tail stock (tail piece?)
What I am trying to do is weld two tubes together perfectly concentric, and hold them tightly together with the tail stock, maybe start with two tacks. I have no idea if it will be able to endure the strain that a weld causes. The tubes are about 5/*" diameter, thin wall, mild steel, and the total part is less than 3" long.
Apparently I need to fabricate a tool that holds a rod in the chuck of the lathe, with a hold drilled through it's center for another rod, that holds the smaller dial indicator (Which I have)
How do you guys center your tail piece?
