What do you mean by "struggling"? Bad finish? Broken insert? What kind of machine are you running on?
The inserts you have are 80 degree diamond inserts (the first C), with 7 degree relief (that's the second C), and a chip breaker (the final T). The type of holder you have will dictate what inserts you can use. Specifically, the inserts with relief built in are usually held "flat" in the older. If that is what your holder is like, you are going to need another insert that also has relief built in (anything other than "N" in the second space). If your holder is holding the insert at an angle, then these are probably not the best inserts for that holder (your are likely gonna break/chip them, especially on something like stainless).
Depending on what you mean by "struggling", you might choose a different insert type. The type you have is (I believe) used for finish work, so, may not stand up well to heavy material removal. Another thing to consider is that carbide likes really high surface speeds, what is the stock diameter, and RPM?
