I have gotten my new lathe inside the garage and started cleaning and improverating it. Now the fun begins!. Here is my lathe:
When I bought it the guy said there was a worn bushing on the power feed lever/cam thingy. When the lever is disengaged it hangs at quite the angle. When engaged it appears to work just fine. I suspect this machine has run a lot with the cam disengaged and the keyway in the ?driveshaft? has egged it out a lot:
So the casting does not have a bushing! It's jut a casting and it is egged out a lot. The one side is1.115" when I believe the nominal size should be 1". The driveshaft is .995" at the end where it is unlikely to be worn. So not I need to make bushings for this. The first question then becomes: Steel (4140 or 12L14) or bronze? I looked up a piece of 1.5"x12" bronze and it is pricey! Even by the inch it is $15.80. Or do I get really clever and put in a set of ball bearings!?
Also, anyone know where to find 20-ish 1/4" Straight Press fit Flip-Top Oil Cups?
