Ahh, a shaper story.....
Bought a used 32 or 36" Cincinnati (can't remember size for sure). Had it brought in on a flatbed trailer, not a low-boy. It was properly right in the center. Not having a large enough forklift to reach out and lift it, and not enough sense to drag it over to the side, I called a nearby used farm tractor dealer/salvage yard and talked them into driving over one of their lifts. It didn't have the reach either, so in a Stroke of Genius, I decided to use both lifts, one on each side of the trailer and get under the machine. Lifting it just off the blocks, the driver pulled the trailer forward, leaving the machine 5 feet off the ground on the last foot or so of each set of forks. So far, so good. Now the idea was to slowly and evenly lower the machine onto blocks where I could get all the way under it. Here's the problem: The loaner forklift had a rather sticky hydraulic valve on the mast control. So, as I lowered my lift, the other operator lowered his.......until his got a little jumpy. My lift got a little lower, and the machine began to slide on the forks. Not having the foresight to have chained the machine off to both lifts, there was nothing to stop the slide. I yelled to the other operator to just lower as fast as possible, hoping to minimize the height of the fall. I dropped my forks, and his were a tad slower than mine, so the load slid my way, and off both sets of forks at about 4 feet up. The ground shook as the 8,000 lb shaper hit the asphalt. At least it was asphalt. It landed on a corner of the cast base, dented the asphalt a good 8-10 inches, and fell onto the side. This is the one time a machine (or anything else for that matter) did not land "butter side down". The only damage other than my ego was a broken belt guard. It was cast iron also, so a bit of brazing and it was good again. We used that shaper for 15 years after that. I don't know where it is now, but I knew where it was at the moment it was conforming readily to the Law of Gravity.
