I don't understand your issue with the lube. A dribble of way oil or a fingertip of grease in the hole and you are good to go. I find keeping the tension on the center to work interface correct as the work heats and cools to be much more tedious, using any center...Yes my question relates to the tail stock end. For the head stock end I will touch up the dead centre before mounting the work so it is dead centre.
For the tail stock end I gather that the only advantage of carbide over a regular centre is durability. Since I have not worn out what I have on hand (3 regular dead centres and a live centre) there doesn't seem to be much point in my getting a carbide dead centre. If it didn't require lube then maybe but that's not the case.
Thanks for your comments.
A Carbide center will probably last your lifetime. But don’t drop it! A ball bearing/live center is another choice/option. For decades, I have every center made in my shop. And can count on one hand the times I needed a dead center. I will crab the live center...Dave
I typed a reply but it disappeared bill
