- Jan 25, 2022
- 129
I read a post (sorry, can't remember where) which suggested trying some 'G' tolerance inserts, as in CCGT, instead of typical CCMT. Stated that the insert is honed to dimension and has sharper edges as a result - finer finish and/or low DOCs.
So, I ordered some CCGTs from Kennametal, and found that the edges were quite sharp. Not quite as sharp as an aluminum insert, but close. Worked quite well on 1045, compared to CCMT.
Not sure that tight tolerance automatically means sharp edges and maybe it was the Kennametal brand, but has anyone seen this effect on 'G' tolerance inserts?
thx
K
thx
K
