- Nov 7, 2019
- 494
Morning!
I'm trying to figure something out with my carbide inserts.
I mostly use CCMT09 and DCMT07 inserts and am finding that they have very short lifetime.
I dial in the speeds so the chip comes off gray/brown-ish but turns blue rather quick and try to feed as much as possible without getting a wavy finish(due to small nose radius).
As an example I was lathing some steel yesterday, nothing overly hard.
Diameter was around 70mm
RPM 440
DOC between 0.5mm and 1mm radially.
Feed ~0.15-0.2mm per revolution
Higher rpm will create sparks, lower makes a very dull/grainy finish.
Lower feed seems to rub more than cut and higher feed makes thick swarf that refuses to break.
With a fresh insert it'll cut really well but the insert quickly(like 10 minutes of cutting) becomes dull and from there it quickly goes downhill.
From what I've read these feeds and speeds are pretty low for carbide, which is why I'm so confused as to why it seems to react so negatively to increased settings?
Any help, suggestion and ideas would be much appreciated!
RPM 440
