- Dec 11, 2011
- 49
Newbie question- I am using HSS on my lathe and happy with it, but I would like to try out some inserts- In my reading I keep hearing that you need a big heavy lathe to effectively use carbide. So the question is: what is big/heavy? Is there a general guideline for how big for inserts? How big do you need before you can go to negative rake inserts and get the advantage of double sided inserts? More curiosity than anything. Thanks-
JP
JP
