Carbide grinding implements???
Glenn Brooks
H-M Supporter - Gold Member
Nov 14, 2014
851
Hello all,
so every one says,"you gotta grind carbide tooling", but I havent seen advice regarding what size of grinder to use, proper wheel grinding speeds, or actual composition/grit of grinding wheels etc. Do you need two different grits? If so, what is best??
I'd like to put together a carbide grinder. Looking for what constitutes a proper set up.
thanks,
Glenn
I only do a bit of carbide grinding so I just switched a 6'' AO wheel for a SiCa wheel in 100 grit. It works fine for sharpening brazed carbide tools.
Not the most sophisticated set up but it got me grinding carbide with a minimum of fuss.
Whatever happened to Christian Poulsen? He'd be the perfect guy to take this question.
Picked up a Harbor Freight cheapie diamond grit grinding wheel, probably for saw blades and made a backing plate /arbor arrangement and use it mounted in old HF mini lathe I picked up cheap well used. Makes for a nice tool for doing brazed carbide. When doing brazed carbide if I need to grind much on the steel shank under the carbide I use AO carefully then touch up the carbide part. I use USA made brazed carbide tooling when doing interrupted cuts and touch em up with the above rig.
Silicon carbide (green) or diamond wheels are needed for grinding carbide.
I use a really hacked method. I use and old washing machine motor running at it's lowest speed (1125rpm I think) and made an arbor to fit the cheap Chinese cup diamond wheels (120 grit) about $10.
The motor is probably to fast but sometimes you just use what you have and it sharpens the cheap brazed carbide pretty well. Made a rest for it and use it pretty often.
I'm going to respectfully disagree with that statement. Green wheels or diamond is desired, but not ''needed''. I grind almost all of my carbide on a standard gray aluminum oxide wheel on my bench grinder. You just have to push a bit harder. Carbide grinds pretty fast once it gets red hot.:rolleyes: I should note that I normally use only the finest Harbor Freight AR8 bits. I do also have both green and diamond grinders, but I rarely use them.
I'm with Jim, All the brazed carbide tools that I use are from HF. Sure, you can spend hundreds on a nice diamond, or silicone carbide grinding set up. Or you could do as I did over 2 years ago. I spent under 10 bucks on some little diamond discs with 1/8 " shanks (like what fits in a Dremel collet). I put the shank of the tool bit in a vise, and sharpen-shape- form, pretty much anything I want to the carbide, If I start getting close to the steel shank under the carbide, I simply switch to an aluminum oxide stone and clear out the steel. In 2 years, I've only used 1 or 2 of the 5 discs that came in a pack with the 1/8" arbor. Now I'm not figuring in the cost of my dremel, I've had it for probably 35 years. If you don't have one, you should have one. Happy Machining, JR49
So, at what speeds are diamond and silicon carbide wheels supposed to spun? I've heard everything from 250 RPM up to 1750....
Thanks,
glenn
I used a silicon carbide wheel on a 6" bench grinder for years. It is set up with the regular tiny little tool rests. It worked okay, but not great. Carbide is hard and I found it ground slow and would heat up. I always meant to make up a good rest - just never quite got around to it.
Because another solution came along: http://www.hobby-machinist.com/threads/carboloy-excello-tool-grinder.37715/
I got a 10" diamond wheel (it is a belt drive machine, runs at about 2000 rpm), designed for grinding on the side, with quite a wide face (I thought I got the grinder at the good price, the wheel cost a crazy amount of $$). It is fantastic, you can grind fast, the tool stays much cooler and it leaves a nice finish on the tool edge.
I'm not saying you should try to look for or duplicate a purpose build industrial carbide pedestal grinder. All I am saying is that a good grinder set up is very nice and I find that a diamond wheel is much better than the SilCar.
Let us know how you make out. Regards, David
