P.S. to the original poster : Dave, if you are reading this, did you ever buy a Nomad, and if so were you happy with the purcashe?
Ah, my first zombie post!
Yes, I went ahead and purchased the Nomad 883 Pro.
It was a perfect machine (for me) to get started with, basically learning CNC from scratch. It is very capable for small scale work in non-ferrous metals. (I'm talking about the 883 Pro).
It is however small - and not just in the sense of volume - I'm not making big stuff. Limited to 1/8" bits. You could put large bits in it with a bigger ER collet, but the spindle just doesn't have the power to take advantage of it. This means that operations that need to remove lots of material (say a 6x6" pocket 1/4" deep) are going to take a long time to clear and will need either very light radial engagement or shallow depth. However, I did a project with a basket weave relief pattern on 4 sides of a 1" cube brass box using end mills down to .01 diameter - and it came out great after I worked out how to get it done.
I also have cut tiny 7 tooth pinion gears (about 3/8 dia) with it that work great.
This past summer, I started working with steel (1018, with the intention of moving to stainless) I was able to use the 883 Pro with some success but my conclusion was that it just wasn't up to the job of anything but very small/light work with steels.
I took the plunge and went for a new Nomad 3 - more spindle power and double the top speed. I have been able to work with steel but it is still a challenge. A caveat here - what I am attempting to do is REALLY pushing the limits of Nomad 3. I've been able to make 1" tail profile cut parts by milling .5" from a side and flipping over to finish. Taking .1 deep by .007 radial cuts with the profile. I can cut a 2d profile in about 2x3" top view area in about 30 minutes. BUT this is after roughing the profile to with in .08 of final using other means. Effectively using the Nomad to make a complicated profile that would be really hard to mill by hand.
I was about to start a thread on my pursuit of this and the issues I'm having and also about the use and availability of small (some would say tiny!) CNC machines.
I have found that there is not a lot of accessible PRACTICAL information on using these machines - most CNC info is aimed at much bigger and powerful machines. It would be great to get some discussion going on here about small scale / desktop CNC.
I'm away for the weekend but look forward to more discussion.
In short, I would strongly recommend getting a Nomad if it fits the kind of work you think you want to do. Sooner or later thought, you will likely want a more capable machine. This is pretty much true for every "first machine" I'm purchased.
