- Feb 13, 2017
- 2,138
The recommended capacitance will be specific for every motor. It is an electrical equivelent to the inductive (winding) part of the motor. I had commented that 250 MFD was a starting point for a 3/4 HP motor. For a 1.0 HP motor, the capacitance will be a little higher. How much higer depends on the inductance involved. Someone had specified a ~500 MFD for that motor. To me, a bit high, but definately doable.
As far as voltage goes, if the motor is used on 120 volts, a 120 volt capacitor would do the job. But having spent many years in the field, I have found that spurious electical noise can damage equipment rated just above line voltage. In this case, where the motor is dual voltage, there is all the more reason to use a higher voltage device. A 240 volt cap would work fine, until some noise comes along and blows a hole in it. Far better would be one rated for 480 volts. It may never see 480 in normal service, but if it did it would survive. Call it cheap insurance. . .
