My machine (lathe/mill) is hooked up as follows: The scale for longitudinal movement on the lathe is cabled to the Z axis input on the adapter and the cross-slide is cabled to the X axis input. There is no third scale, so the Y axis input is empty. No other input is connected.
I managed to get both a 'lathe' and 'mill' configuration set up. The lathe was straightforward. For the mill, I changed the label on the Z axis to 'X' and the label on the X axis to 'Y'. The main display looks like I expect and I got the axes to increase in the expected directions.
Is this the correct way to do it?
Using the MILL configuration the following happens:
When I create a sub-datum entry, it is filled with absolute coordinates from the main display BUT x is set to the Y-abs reading, y is set to zero, and z is set to the X-abs reading. (Apparently using the x, y, z nomenclature from the adapter point of view.)
When I edit that sub-datum, it only allows one input labeled 'x' which is the one from the Y axis display. (the x from the adapter point of view)
I'm really new the the whole DRO business and am only a really hobby-level machinist and of course I have only entry-level equipment. I spent 40 years as a software developer, so I know what goes into a product like TouchDRO. You're doing a good job. If I can do any helpful testing with my odd-ball set-up, please let me know.
To be frank, it would be easier for me to use the lathe coordinates for my mill work, but the edge-finder feature would be really nice!
