The old add-on for rotating attachments is obsolete. I've installed a newer add-on to be able to rotate attachments. You can also resize them and add a border. Go ahead and try it here if you want.
The ONLY rule to be able to successfully use this feature is that the image MUST be a jpg. If I can find an add-on at a later date that will manipulate other image formats, I'll replace this one with that.
