- Oct 29, 2012
- 1,387
I was gifted a scroll compressor module (ATSL-165E) out of an Atlas Copco industrial skid compressor and I want to use it for my home shop compressor, but I can't justify throwing much money at it. It's just a 5HP 230V/460V 3ph motor and a scroll compressor mounted to a plate, coupled to each other by a couple of V-belts.
I have some 3HP motors and VFDs but no 5HP VFDs. I was thinking I will just replace the one or both of the pulleys (maybe the motor too) for a lower gearing solution; sacrifice some volume to work with what I have. But I'm not sure if you can do that. I know that piston compressors need to be run at a certain speed for splash lubrication to work, but I don't think that's a concern with a scroll compressor. But there might be some other thing I don't know about. Maybe the scroll has to run at rated speed to develop pressure? Maybe the compressor can't cool itself at reduced speed? Any gotchas?
