- Jan 25, 2015
- 2,558
I’ve always though my TH42 (10F) was a mid fifties build, but in tearing it down to paint, I’ve found some casting numbers in the bed ways.
I’ve read that there is usually casting numbers between the ways and its roughly a year prior to when the lathe was “built”. Seems the story goes that Atlas had the ways cast and ground and then left to age for about a year to let it warp or twist if its going to.
The casting marks are not exactly definitive. One mark is just a “W” in a raised oval and the other is “842” by itself. no other casting marks were evident.
The lathe data plate;
087321.
Coukd the casting number mean 8 month 1942? Which I guess woukd mean its around a 1943 build date?
I thought maybe its part of a julian date code, but 842 isn’t on a julian calender.
Anyone want to take a swing at what the build date is?
087321.
