- Aug 5, 2013
- 281
I was bronze sleeving this bracket after I bored it our, BUT, I forgot to grind down some hard raised spots in the bore before I pushed the sleeve in, and I mis-measured the OD of the sleeve.. It was .004 larger than the bore.. I was aiming for .001... So 2 stupid mistakes.
This bracket Holds drive shaft for table power feed on a horizontal mill.
Anyway, now I have to repair this CI bracket before I re-sleeve it with the proper OD sleeve.. I was thinking about silver soldering, then make the sleeve slightly under size, and JB welding it in place..
I am thinking brazing might warp this bracket..
The crack closes up when i clamp in vise.
Or just make a slightly undersized sleeve and JB welding, without silver soldering.
Any thoughts on this, or or other suggestions..
And it was going so well...
Thanks
Dan
Thanks
Dan
