but at the tip, where (I assume) it's heat treated? I'm thinking to turn either a drill bit or an end mill into a cap head counterbore bit.I don't know about endmills but I've turned a lot of drill bit shanks down for friends and carbide cut them just fine.
I'm getting the feeling that you're sparing me a couple of semesters worth of in-depth technical explanation with this line. So it would be more complicated than heating it to non-ferrous, and then dunking it in ATF? I have an acetylene torchAs far as annealing a high speed steel drill, you can, but then you wouldn't be able to harden it again because heat treating high speed steel is pretty much out of reach of most hobby metallurgists.
Well the question is mainly just a theory question, but I actually do want to make some counterbore bits for cap head screws.What is it you are trying to do?
Tom
