Hi all - Newbie here- my second post.
I want to replace my lantern toolpost on my 56TH 10F ATLAS. Probably too late to ask this question since I already received an AXA from CDCO this week, but can this be made to fit my 10" ATLAS? The T-nut is way too big for my machine. I've already gotten a 1/2"X 4" grade 5 bolt locally to replace the 9/16" , and if I add a 1/8" spacer under the toolpost it will swivel without hitting the top of the slide. I plan to cut down the head of the new 1/2 X 4" bolt to fit my existing t-nut(the one that came with the lathe), and it looks like it will work. A little sloppy in the holder bore, but I can add a shim to make the 1/2" bolt snug in the bore, if that's a problem. I'd just like to know if I am going to spend the time to make a new hold-down bolt, only to find out later that there is some other problem with this set up. (Maybe the tool holders locate too high or too low to be used correctly?) Should I just bite the bullet and return it to CDCO and buy something else? I don't want to fiddle around modifying this a couple of weeks, then find out I can't return this one because it's beyond 30 days.
Am I barking up the wrong tree, or is this just normal for adding a QCTP? I'd love to be able to make this work. I've noticed in many ads for mini lathes that the t-nut would have to be fitted. If that's what it is - no problem. The CDCO ad said it was for a 10" lathe, but maybe the ATLAS cross-slide runs small?
Thanks in advance for advice on these questions.
Banjo5
Banjo5
