- Feb 8, 2014
- 11,176
Regarding my questions, found that multipass is covered by a Wizard within Mach3, however still don't know how to tell it to cut inside/outside/on centered on the line. CamBam allows selection of Inside/Outside but nothing about cutting centered on the line. Wonder if I have to offset drawing features to accommodate tool diameters before I generate G-code from a CAM program. Might not be too hard for simple stuff but seems like there has to be a better way. Will keep looking, who knows what I might find. Take care and keep us posted on progress, will do same.
Burt
In the CamBam Profile Operation setup area there is a option of Inside or Outside. This does not exist in the other Operation setups. To cut on the center line, choose the Engrave Operation, there is no tool offset other than cut width value. Another way to cut on the center line is to choose the Profile Operation and set the tool diameter to 0.001
CamBam will create a tool path based on the tool diameter that you input in the Profile and Pocket Operations, it is not necessary to offset the drawing. Make your drawing on size at a 1:1 scale.
