Greetings! New member here first post.
I am searching for a mid sized (bigger than a bench mill but smaller than a Bridgeport) used mill. This would be my first piece of metal working machinery, although I have purchased, used, and reconditioned used vintage woodworking machinery and vehicles in the past. So I have some small mechanical aptitude anyways.
I've scoured Craigslist, FB Marketplace and Kijiji locally and will continue to do so. But it seems likely that I will buy via ebay or from a dealer website, and in that case I will probably not be able to inspect the machine personally.
General stuff like which mill I should buy, the specs on the machine, previous use and ownership, damaged/missing/loose items, options, tooling included, power requirements, etc I can cover.
What I would like to get some advice on, and I am sure this has been asked many times before, is what should I look for / ask the seller in order to determine if the mill can be used as is or if it is need of major rework? I'm thinking wear on the ways, excessive backlash, things of that nature?
Thanks!
Dan
Thanks!
Dan
