I intend to replace the bushings in my old lathe, primarily because then I oil the spindle pulley it throws oil for the next 5 minutes.
I can get to the spindle and counter shaft bushings and found these sizes:
spindle bushings: ID = 1.500, OD = 1.750, L = 0.814 x 3 ea.
counter shaft bushings: ID = 0.750, OD = 0.875, L = 1.5 x 2 ea.
The back gear shaft is scored where the set screw has been tightened (I think) and I'll have to ruin the bushings to be able to measure them. This is what I think they are:
back gear: ID = 0.500, OD = 0.625, L = 0.625 x 2ea.
I'm hoping someone here can verify the size before I ruin the bushings by removing them and then find I've bought the wrong size.
Thanks,
MikeMc
Thanks,
MikeMc
