Thank you very much for the responses and pointers. Footprint is more like 7' wide by 6' deep. I have the room, but it is a beast. Yet, ability to load up the tool paths, speeds, and feeds seems so much easier than manual and I like the ability to work on "shop" size parts. I have a couple of mini tracked dumpers to convert hydro-static drive, a number of brackets to make- nothing "job" related, just a ton of odd end projects that I could use a mill, can't fathom paying local shop costs. I'd like to get my son into machining too, and being able to witness design, program, and setup (using electronics) would be much more engaging (to him) than attempting to go "all manual."
It spooks me a little as it's not going to leave the residence very easily....as my wife asked..."so, if we ever sell (the house), it (the mill) stays, right?"
Might take a look at it this Saturday. Have to get an idea what a rigging outfit wants to transport. Gas cost, very hot drive in an old truck, renting a trailer with lousy suspension, and then trying to off load up a steep uneven driveway makes me think letting someone else move might be the way to go...if the price is right?
I'm also curious about current load. I need to talk with my electrician to see if the 220 circuit that used to power my hot tub can be repurposed with a phase generator and still have enough current to power her up. 80's electronics pulled some juice! I think the owner mentioned the spindle motor is rated at 2hp.
I guess the question is if would make sense to hold out for something newer, smaller...but then work size gets limited. Hmm,
