- Feb 4, 2021
- 184
Hey Guys,
First off, not sure if this should go here, or the Burke forum. I'll try here first.
I think it is time to replace the original motor on my Burke No. 4. Not original to the Burke, but originally came with the Burke to me. The Burke is a 1920's era I believe, and was originally run via a flat belt from above. It has been retrofitted with a 1/2 hp (1725 rpm) motor through a 90 degree speed reducer to a countershaft to the spindle. The original motor is quite old, and runs quite hot, and a bit loud. It originally had brass bushings that I replaced with needle bearings. I have two replacement motors, and I'm not sure which to use.
Number One:
GE (capacitor)
1/2 hp
115 v
1725 rpm
Code M
SF 1.25
Continuous Duty
Number Two
Dayton (split-phase)
1/2 hp
115 v
1725 rpm
Code P
SF 1.0
No Mention of Duty
Type FHT < not sure what this is
Not that it matters, but the Dayton weighs about twice as much as the GE.
What are your thoughts on which would be a better replacement motor?
Thanks a bunch,
Greg
Number One:
GE (capacitor)
1/2 hp
115 v
1725 rpm
Code M
SF 1.25
Continuous Duty
Number Two
1/2 hp
115 v
1725 rpm
Code P
SF 1.0
No Mention of Duty
Thanks a bunch,
Greg
