- Jan 21, 2011
- 94
I finished firing the first 100 hand loads through my .223. 68 grain Hornady match
bullets with 25 grains of Varget .010" off the lands gave very good results.
Accurately measuring the bullet length and getting the correct distance off the lands in a pain.
So in order to not have to do it every time I try a different bullet I made this simple tool.
I had an old .22 barrel lying in my metal pile I made the two parts out of it. The smaller insert is 2" long and .375" in diameter.
The larger part is 5/8" OD and I drilled and bored it so a fire formed .223 case would slide through it almost exactly .375"
There is a setscrew about .375" from the end to lock the two parts together.
You set the larger tube on a loaded round on a flat surface and slide the smaller part in till the rifling touches the bullet
and tighten the setscrew. and the measurement is recorded.
I will make one of these for all of the bullets that I will use in the rifle.
Terry
Terry
