The 10-256 Direct Drive Pin that you push in to lock the cone pulley to the bull gear is a nominal 1/2" diameter. by 1.35" long. It has near one end a 1/2" wide slot cut across it to a depth of about 0.1". Adjacent to each side of the slot is a dimple made with a 3/16" diameter ball mill. The visible end of the pin has a groove turned around it that a special tool or a screwdriver can be hooked into to pull the pin out with.
The 9-60 detent plunger is 3/16" diameter with one end being a ball end. There is a 3/16" diameter hole drilled between two adjacent bull gear teeth that goes through the 1/2" diameter hole through the bull gear web. To assemble, you first drop the 9-61 detent spring into the 3/16" hole and then drop the plunger on top of the spring, ball end up. With a special tool, you push the plunger down against the spring and slide the direct drive pin into the hole through the side of the gear, ending with the plunger in one of the dimples. To disassemble, you first rotate the direct drive pin 180 degrees, place your thumb or probably safer something like a putty knife blade over the hole between the gear teeth (to keep from losing the detent pin) and slide the direct drive pin out. To retrieve the plunger and spring, use a small magnet.
There is a reverse engineered drawing of 10-256 in Downloads.
