Last year I bought a 5x8 utility trailer and upgraded the heck out of it while teaching myself how to weld. Well now I enjoyed that so much I want to try something bigger.
I plan on building a pressure washing, hydroseeding, and fire fighting trailer unit, gonna have a skid mount hydroseeder, a big pressure washer, a water pump, and 2 ibc totes full of water.
The majority of the weight on the trailer will be about 5500lbs of water when its full (assuming 2 full 330 gallon ibc totes), and that plus all the equipment I figure to be safe that's about 7000lbs total, so I'm thinking an 8000 or 9000lb axle.
With leaf springs do I get them by the weight rating on the spring or on the axle? Would I get 2 8000lb springs for a trailer with a 8000lb axle, or would I get 2 4000lb springs for it? What do y'all suggest for the main frame / body of the trailer? Is C channel enough or should I go for square tubing? What thickness? I'm really new to metalworking in general and want to make sure to overbuild everything for safety since I'll be driving it on the road. If I need 3 1/4" angle iron braces I'll put 4 3/8" braces...
Is there some guide or source material I can read that will teach me how to calculate the weight a given profile needs to permanently deform? I want to learn how to pick/calculate what thickness material I need for a given project.
